Pauly,
I guess stranger things have happened I use Thunder Power 1320s. Looks like Helihobby is going to take good care of your situation.
If you don't use the new bracket the swash plate will be in a bind.
Today while flying in the garage my Blade jumped into the air and got real wild and as luck would have it I was able to get control in time to land safely. It turned out to be the 4 in 1 crystal was loose. The 4 in 1 red light came on and stayed on until I discovered the problem. I am trying to learn head in flying. It is just like starting over from scratch. I can do everything else but the head in[
]. It will just take practice. Winter is now setting in in KC and I have to fly in the garage.
Good luck with the Swash plate.
Don
