Why So Many CG Questions?
For thermal duration, you want the CG at the point where you max more often. This is a compromise between an aft CG for straight-line efficiency, and a forward CG for stability. The better and more aggressive the pilot, the more aft the CG tends to be. It takes hundreds of flights and good record keeping. Virtually every serious model sailplane pilot I ever met does it this way.
