RCU Forums - View Single Post - Replacing CA hinges
Old 11-28-2005 | 08:35 PM
PropSpinner's Avatar
PropSpinner
My Feedback: (15)
Default Replacing CA hinges
I'm not really a beginner but this belongs in the beginners forum.
I have a plane with CA hinges that had a small accident. After a closer inspection I found that one of the CA hinges was damaged on the rudder. The fabric that is sandwiched on each side of the plastic came off leaving the fabric in the wood and the plastic on the outside. Whatever the solution I think I will end up having to cut the other hinges to be able to fix the problem.
Has anyone had to replace CA hinges and what was your solution?
