RE: Great Planes Super Sportster EP with Modified Power System
I noticed that several people are using 3300 mah packs in their Super Sportster. As these packs are heavier than the stock NICD pack and the plane is a little nose heavy with the stock pack I thought it would be better to use a different pack configuration to move more weight rearward. Has anyone tried a hump pack or other config with the 3300 mah packs. I was a little concerned about fitting it through the opening.
Thanks for any input.
Denzil
