RCU Forums - View Single Post - Kioritz Echo Question
Old 11-29-2005 | 12:16 PM
tim220225's Avatar
tim220225
Default RE: Kioritz Echo Question
That saw was made in the early 80's and the case is the block. You would need to cut and grind the case down to something useable. I have done many trimmer and blower motors but there is a lot less material to remove. I have done one like yours but I used a Bridgeport mill to make nice angles and radii cuts. Looks cool too.
Try these links:
http://www.echo-usa.com/technicalresults.asp?model=601s
http://www.echo-usa.com/oot/docs/CS601SE_050275.pdf
Good luck.
Tim
