RE: Funtana 90 rolling tendency
Did you balance the plane laterally? (ie add weight to the left wingtip as needed)
I held the plane using string from the rudder post and another string around the bulkhead at the front with the canopy off. The front string was carfully attached to the frame at the center. Then I put about 1/2 oz of lead in the left wingtip (remove covering, glue in place with CA, light glass cloth).
