RCU Forums - View Single Post - Quick engine question
Old 11-29-2005 | 08:22 PM
E-snake's Avatar
E-snake
Default RE: Quick engine question
somtimes if you put a larger than average head on an engine, you run into problems because the engine runs too cool. You don't want the engine to run too cool or the piston won't shrink enough. This will cause a tighter piston/sleeve fit and could wear your engine out faster. It would be especialy tight at the top of the cylinder brcause it is tapered.
Ethan
