RE: Got my NEW Edge
I worked on the Edge yet again today. I was a zombie after I got done with everything so I figured a little R&R was deserved. I went to Hobbytown to pick up some more E/Z Connectors and I get to return tomorrow to get more. I keep loosing that little snap retainer when I'm trying to put it on. It goes flying across the room and I can't find it. Anyone know if you can get those at a hardware store? I might go by there tomorrow and look first. I cut and glued the carbon fiber pushrods and I'll have pics of those tomorrow. Then I added some CF tubing over the throttle pushrod which took the bending out of it so I get good resolution now. Also installed a choke servo and the rudder servo. On a different note, how does my method of securing the ignition signat wire look? Is it good or do I need to do something different? And what do I need to do with the ignition wire? I don't want it rubbing against the muffler.
