RCU Forums - View Single Post - Contest: Free 14mm Wheel adaptors (funfactor)
Old 11-30-2005 | 08:05 AM
nitromacguyver's Avatar
nitromacguyver
Default RE: Contest: Free 14mm Wheel adaptors (funfactor)
one thing i learned in my drawing and painting class two years ago, logos are amoung the hardest things to do. the reason--> writer's/artist's block. good luck to those that are trying.
hey doc, if you take a look in my gallery you will see the chassis brace i made for my truck. i kept bending the center drive shaft when i hit curbs and stuff or let my little cousins try driving.
anyway, would you consider producing such an accessory? it involves replacing the throttle servo mounts with aluminum, making a brace bar to go between the servo mounts so the servo doesnt transfer the forces of collision and making a brace to go between the brake seat and the rear throttle servo mount. it would require some work and time, but i would think that it would be something that people would buy.
that and diff cup rings. just little pieces of tube that have been bored out to the exact diameter of the diff cups which are famous for breaking. just some thoughts.
