RE: Control surface trailing edges
I typically just square off the trailing edges. My ailerons are usually tapered because the leading edge is so thick to begin with. The T.E. ends up being about 1/8"-3/32" thick. Aerodynamaically, you get better, cleaner air separation using squared edges vs rounded. Clean separation helps eliminate flutter.
Dr.1
