RCU Forums - View Single Post - Foam Kit Building
Old 11-30-2005 | 05:44 PM
Reverse_Sensing
Default RE: Foam Kit Building
Hey guys, Im sorry to keep bugging you with more questions, this time its about the glue. Do you guys use the kind recommended by JKA (Goop??) or do you have something else that you prefer. I understand about the 3M-77 for pre-taping or covering but what about sticking the fuselage halves together and any other parts? Montague - thanks for the imput about the radio equipment. It looks like the Hitec 555 reciever and HS-81 servos might do the trick, like you suggested, Ill make sure to get them compatable with the Futaba J. How big of battery do you use? Do you think a 270 mAh will suffice for a flight at a time or would you recommend larger?
