RCU Forums - View Single Post - Control surface trailing edges
Old 11-30-2005 | 06:11 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Control surface trailing edges
Square corners help prevent flutter and rounded corners promote flutter.
If you want to taper you can slice and inlay 1/64 ply into the edge and taper down to it. Make a cutter by screwing a #11 blade down with a shim underneath that is equal to half the thickness of the TE before trimming. Slide the TE across the blade and you have a slot for the 1/64 ply. You can easily taped down to it. Seal it in with thin CA.
Another thing is to taper to a sharp edge, then soak the edge with thin CA to harden the wood.
Personally, I leave mine square.
Here's a photo of the TE of the aileron of a Morris TopCap 3D plane.
