RE: 2006 Sportsman and Intermediate Sequence
A slightly different way to have a caller read this to you.
1. Hammerhead; 2 of 8 up, 3/4 roll down
2. Half Cuban 8; 1/2 roll, push 5/8 loop, positive snap
on the 45 downline
3. Immelman
4. 1- 1/4 positive spin, exit cross box
5. Humpty Bump; 2 of 4 up, 1/4 roll down
6. Full roll on a vertical upline, exit inverted
7. A two point roll into a down half loop
8. Loop with a full roll at the top
9. Pull 135 degrees, 2 of 4 on the 45 upline, exit upright
10. Downward Figure 9; 1/2 roll on entry, 3/4 roll roll on
the upline, exit cross box
Some times simple is better. Which ever way is good for you, it is easier if you practice hearing it called to you also.
Good Luck
Greg
