Hi,
If the 2 sets screws have been locktite in, then its possible that its got to the shaft and then this can be a pig to get off. The best thing I use is a soldering iron (40watt ish) and put this on the block for a while, then twist and pull. You can use a small blow touch but if you have to much plastic around, TAKE CARE!!...lol
Steve
