RCU Forums - View Single Post - breaking in DA-100 and problem need help
Old 12-01-2005 | 09:52 AM
Geistware
My Feedback: (16)
Default RE: breaking in DA-100 and problem need help
I would check two things.
First, remove the cover plate (non-diaphram side) and see if you have crude on the screen. Blow it off with Carb Cleaner.
Second, make sure your ignition battery is charged and you have no loose connections.
If it still doesn't run, then send it back.
I think you already know not to run it on a stand.
