RE: Open Source Scratch Build?
Good to here from you Mike. I'm glad the redesign of the wing is going well. Maybe after I get all of the airfoil stuff done, you can take a look. The Mig used Clark YH (14%) at the root and a Clark YH (8%) at the tips. Though I haven't studied the docs I have, I think that I will include at least 2 Degrees of washout in the wing. It also had a pretty thin wing tip and I am not sure if I should use a "scale" airfoil, or tweek it a bit for better "Model" size performance. Your experience on the LaGG-3 would be great.
