RE: warm synthesised module
Do not run with the transmitter antenna retracted, extend it fully except during the brief time it is on for range tests. A collapsed or partially collapsed antenna will cause unecessary hot running as the SWR causes most of the energy that would normally be radiated to be dissipated as heat in the output transistor.
