RE: Air Hogs Aero Ace!
micro builder - thank you. I removed the lower wing and attached it to the upper wing. A .32 wire and dubro 3/4" tires on the front, a small bent 45 degree .32 wire on the tail as a skid is what I finally decided on. Flew fine but I could not ROG. The plane spun in a circle to its left at full throttle. I'll try to figure out what is going wrong and correct it. The plane looks very similar to a HZ Scout in this configuration. With the extended wing alteration, has anybody experienced an inablility to steer. I'm finding it more difficult to get out of a spiral once it has started, usually to its right. Is there anyway to correct this?
