ORIGINAL: flier
Ben,
Wrap a piece of fuel tubing (split down the side) around the pick up wire for better protection and then secure with a few cable ties.
The insulation could vibrate against the engine mount and be worn through.
Everything else is looking real good.
Thanks for the tip flier, I'll be sure to do that. I may just do a few inches since most of the wire is not near anything. Now, I just have to figure out what to do with the wire going to the spark plug. The Edge is almost done, I'm basically just waiting on the new wing panels so I can balance it. I have the plywood plates glued to the wheel pants. I need to add axles and wheels on the landing gear. Got the pull-pull going now that I got some more crimps. Radio for the elevators and throttle/choke is good to go. I have batteries and switches installed now to. Probably get the glue going on the canopy tomorrow.
