RCU Forums - View Single Post - thrust tubes can you help
Old 12-02-2005 | 10:04 PM
joeflyer
My Feedback: (49)
Default RE: thrust tubes can you help
Donnie,
Is this for the TGA F-15 you have mentioned in previous posts? For a Byron fan the best way to go, by far, is with mylar. It is strong, light, fuel proof, and cuts easy with a scissors. You can get it at a drafting or a plastics supply store. If you don't have an old tube to use as a pattern just wrap one end around the fan, size the other end to the exit nozzle, trim it with a scissors, leave a half inch overlap seam, and glue it together with CA. Make sure the seam is at the top. I also wrapped mine on the outside a couple of places with fiberglass reinforced packaging tape.
Very easy and will last forever.
Joe
