RCU Forums - View Single Post - U-STICK can HOVER
Old 11-13-2002 | 01:53 AM
Johnnylightning
Default U-STICK can HOVER
...and nose gear steering arms, on both sides, not only hold the 5/16" rod in place, but also drive the 2-56 rods to the control horns simultaneously. And, the nose gear steering arm on the other side is connected to the servo that drives the entire mechanism w/ a 4-40 rod. IMPORTANT: The 5/16" rod MUST be filed flat at the point where the steering arm set screw makes contact w/ it.
