RCU Forums - View Single Post - Got my NEW Edge
Old 12-03-2005 | 02:08 AM
  #44
ben beyer's Avatar
ben beyer
My Feedback: (23)
Default RE: Got my NEW Edge
I worked on the wheel pants tonight. As usual, I used Sig wheel pant mounts. If you have never used these, I suggest that you pick some up and try them out. I had to make my own plywood mounts, but if you can work a saw, that's easy enough. I took flier's advice and put some fuel tubing on the ignition signal wire. Gotta go by a small engine store and get something to cover the wire going to the spark plug or figure something out.
ID:	364029   Click image for larger version
ID:	364030   Click image for larger version
ID:	364031   Click image for larger version
ID:	364032   Click image for larger version
ID:	364033   Click image for larger version
