RCU Forums - View Single Post - 9C - changing slider reference
Old 12-03-2005 | 02:09 AM
redjet
Default RE: 9C - changing slider reference
Bill,
Thank you for the help, but you suggest a complete new setup that is different from the FAQ version for quad flaps. I really didn't want to redo the entire program - all I was requesting was how to perform step 10 of FAQ 40 to move the slider to the up position and still be able to use the flaps for continuous ailerons. Everything else works fine.
I can activate the left slider (Vr-D) and with the slider in the middle of its range - can get the flaps to go full range both up and down. By disconnecting the linkage at the flap servos and moving the slider to the up position (toward antenna) and reinstalling the linkage in the neutral position - the flaps now only go down (if I move the slider) which is what I want. However, when I activate continuous ailerons, the flaps will track downward with the ailerons but will not go up - pass neutral.
By step 10 being in the FAQ it seems to imply that I should still be able to get the continuous ailerons after moving the slider and flap linkage.
I believe Krista worked on this setup in previous posts.
Sorry to drag this out.
