RE: thrust tubes can you help
I Donnie,
I agree with both Terry and Joe, i had same problem too on my TGA F15, i made my thrust tube with mylar by wrapping it around byron fan shroud and then letting otherend around both exhaust nozzles onepings, but you have to make sure that outer end is bigger in diameter just enough to go around both both outlets. I kept my seam on the top also....
Sammy
