It is not recommended to CA the mylar thrust tubs together, use the clear packing tape. The Ca makes the Mylar brittle and it will crack. As others have stated keep the seam at the top so when at rest the oil will not puddle on the seam. There will be a lot of oil in there unless you are going electric.
