RE: Question air comp and tool oilers and paint
You'll still need to drain condensate from the tank regularly. The compressor will still inhale air with moisture in it, the moisture will condense in the tank, and if you let it build up, or don't drain the filter and the tank regularly, it will get through to the tool or sprayer.
Good luck,
Dave Olson
