RCU Forums - View Single Post - 9c rocks for 3-D!!!
Old 11-16-2002 | 04:31 AM
  #38
OnTheEdge
Default Re: Flight Condition
Originally posted by mecam
Flight conditions allows me to have a single switch that would switch my elevator, aileron, and rudder to 3D rates from normal instead of having 3 different switches for each control surfaces.
The 9C can assign all three control surfaces to the same switch as well as set up expo.
As an FYI for those of you with the 9C, for about $20 (Great Planes Hobby Services) you can get the two-position switch (Switch B) upgraded to a THREE-position switch! Apparently the software supports this upgrade and you now have a three positon switch on the left side of the radio. I had this upgrade done to mine as I wanted to assign triple rates to that one switch on the LEFT side. My thought is that when all h#ll breaks loose, I fly out with my right stick while using my left hand to reach for the triple rate switch. Maybe it's just me but in a panic I'm not comfortable trying to find a switch on the right. the replacement switch is also one of the "taller" switches thus making it easier to find.
So far I love the radio only I picked the wrong frequency. Went to my first IMAC meet and out of about 25 pilots, 5 of them were on channel 52. Went flying at my local field the other night. Six guys and three of them on channel 52. Guess which channel I'm on????
............Mark
