RCU Forums - View Single Post - Help with Build problem
Old 12-04-2005 | 09:58 AM
jbloom
Default Help with Build problem
I am building an old kit I bought off of e-bay. It's a Wolff Pak Thrush. I have one that is already built that I'm flying now, but it's wearing out. So, I started building the kit I've had laying around for a bit. Here's the issue. After getting the fuse build I noticed that the bulkhead that supports the landing gear is shorter than the one in the plane I'm flying, and after looking at the pics in the manual (no plans) I can see that it's supposed to stick up a bit. I can fashion an extention by laminating 2 1/8th pieces of ply wood around 2 5/32 pieces that create a pocket for the landing gear. Do you think this is the best method? Is it too little a problem to worry about? My concern is that there is a hole for the wing dowel that will also be located too low if I leave it as is. Here are some pics.
ID:	364625   Click image for larger version
ID:	364626   Click image for larger version
ID:	364627   Click image for larger version
