RE: Sun Dancer 50
SUN DANCER 50 ARF The SUN DANCER 50 ARF is a perfect combination of biplane looks and attitude! From any angle, it's beautiful lines speak volumes about its performance potential. And like its giant scale counterpart, the SUN DANCER 50 ARF is loaded with great flying characteristics.
The ARF features beautifully built balsa and plywood components, covered with SIG AeroKote.. Typical SIG attention to detail with features like, factory painted landing gear, fiberglass wheel pants, cowl and cabane struts.
Specifications:
Wing Span (Top) 1219 mm 48 in.
Wing Area (Total) 48.8 dm² 757 in²
Length 1143 mm 45 in.
Weight 2722 g 6 lbs.
Radio Required: 4 Channel, 5 Standard Servos
Engine Required: 7.5 - 8.7 cm³ .46 - .53 2-Stroke Glow
9.2 - 11.8 cm³ .56 - .72 4-Stroke Glow
Also includes factory covered interplane struts, quality hardware, superb decals and SIG's famous complete Assembly Manual - all combine to make the SUN DANCER 50 ARF a true quality package.
In the air it's a fully capable aerobatic model with a huge flight envelope. Landings can be almost as slow as you like and the airplane ground handles perfectly. With a choice of two distinctive color schemes - either will make your SUN DANCER 50 ARF a real standout at the field!
