RE: YS 91 AC HELP!
Hi Walt,
The engine will run up but it sounds a bit rough. When you turn the high speed needle in it does not change much. Also as I said, you can turn it all the way closed and it will keep running.
Do you know if it should keep running with the high needle in all the way? Does that say there is something seriously wrong? An air leak? Maybe that is from the leaking o ring?
Darren
