RE: OTOP PICS!!!
Hi Tommy S,
This is the new body that Extreme Comp sent me after the first one broke. The first one was a very early one out of production and had the rear former mounted vertical, since then I believe they have mounted that former on the same angle as the vertical fin and the hortizal one through the stab area up to it. I have also put in a depron plate down the body from the former to past the pipe tunel floor, it is also at a different height to the stab former so there is a overlap of these hoztizal formers at the angled vertical former. Also I placed 15 grams of lead in the front of the counter balance of the rudder.
All of this I did so hopefully it won't do it again and seen all the Impact owners are doing these mod's I thought I should do them as well seen they are made of the same material. Now it is flying again I have given it a very hard time in high G 3D manoeuvre's and its still flying.
