RCU Forums - View Single Post - Servo Load
Thread: Servo Load
Old 12-05-2005 | 10:38 PM
BMatthews's Avatar
BMatthews
Default RE: Servo Load
ORIGINAL: dick Hanson
Good luck-depending on how you elect to fly a model - I would bet the margin of error is about----500%
I don't know if it's THAT bad but you gotta input some reasonable worst case numbers. Size and throw angles are no big deal. Easy to measure and all. But the speed is the kicker. You need to figure out a reasonable terminal velocity for a longer dive and input that as a worst case. What that speed is depends a lot on the model, power source and prop. And in the end if this is a 3D type model with huge surfaces then you need to figure on YOU limiting the dive speed by not using full throttle or you'll require far larger servos.
