RE: How do I set up kill switch on G26? Simultaneous Servo and switch??
A switch in the black wire lead simply shorts out the coil to ground stopping the engine. Get a hefty slide switch from Radio Shack for manually stopping the engine. You can stop it from the radio by removing the throttle stop on the Carb, and reducing the throttle below idle. The butterfly will close completely, and she stops !
> Jim
