IMHO the carbon fiber symmetrical blades are only for once you have managed to start going into acrobatics with this heli. If you're not doing stall turns, flips, loops, and rolls then you have no reason to be using the CF sym blades. Trust me I learned this one myself and I'm even working on acrobatics right now myself. I'm not spending the money on another set of CF blades. I'd rather spend the money on cheap wood blades that take 20 seconds to install then spend 10 hours trying to track down vibrations and wobbles from a damaged head due to a ground strike with the CF blades. Go ahead and put them on your heli but be warned.
I don't need the bling of the CF blades and with some time the woodies can track just as nicely as the CF blades... Sharpies can make the woodies look pretty nice too
