RCU Forums - View Single Post - How do I set up kill switch on G26? Simultaneous Servo and switch??
Old 12-06-2005 | 06:40 AM
Dr1Driver
Default RE: How do I set up kill switch on G26? Simultaneous Servo and switch??
The black wire shorts the primary side of the coil to a known ground. A parallel connection will not kill the engine if only one switch is closed. You must use a series circuit. I use a sturdy SPST (single pole-single throw) toggle switch from Radio Shack. Simply run the black wire to one terminal and the other terminal to the engine block. You can use a micro switch activated by a servo for the electronic-operated killer.
Dr.1
