Tower has the plane for $70 and you can download and review the build manual there to see if this is what you want. It would be a good plane IMO for you. Be sure to build it in the "trainer" version.
I am unfamiliar with Hitec but I checked the price and it would be good if NEW. I would not recommend buying used radios if that is what this is. Too many hidden possibilities although it may also be fine.
Engine choice is OK. Tower sells for $68
http://www2.towerhobbies.com/cgi-bin...&I=LXGGV7&P=ML
You may already have these prices or better ones. Just thought I would throw them in for you.
When I build I like to use Tite Bond II. A good quality wood glue, not a CA type. Takes longer to set/dry but gives more time to position parts properly. You also won't glue your hand to the plane.
Some people are also very allergic to CA glues, use good ventilation if you go that way.
Check at your local hobby shop (LHS) for club info or at
www.modelaircraft.org they have a club locator section that you can plug your zip code into and find clubs in your area.
You are right about there being a large number of people here from Greater Houston area. Even me, 17+ years ago.
Welcome to the hobby/sport and enjoy it with us.
