RCU Forums - View Single Post - Servo Load
Thread: Servo Load
Old 12-06-2005 | 10:39 PM
uby's Avatar
uby
Default RE: Servo Load
www.camodel.com.ar --- you can find the fantasy here.
ORIGINAL: dick Hanson
Depends on how you fly it - actually the inexpensive JR811 digitals will do the job! they are rated at 55 in ozs at 4.8 v -I have used them on 3D 2mm ZDZ40 powered setup -no problem - On the Fantasy -I assume(?) you are not into wild throws
the JR9411SA is reaqlly excellent and smaller -costs more tho 90+ in ozs torque. good digitals are really best for really precise stuff as they have far greater ability to hold a position The effective deadband is far smaller .
The 9011 are good too -but I like the digitals -- I used the 9011 on my Bucker Youngman (four ailerons) 1780 squares.
I fly it in pattern and some wild 3D. My new project is a 2 m (designed by me) and has about control surfaces 3 inches wide and full length along the ailerons.
You said 9011 is good but you like digitals. I've already spent a lot on this machine and Was thinking that my 9011 could come in handy. I am using a pull pull setup on my rudder and both elevators have separate servos with pull pull configuration.
And ofcourse the ailerons have simple pushrods but I think there'll be a lot of force on these ailerons when inflight.
