RCU Forums - View Single Post - Invacare Motor Help
Old 12-06-2005 | 11:13 PM
WhiteWolf McBride
Default RE: Invacare Motor Help
Mitch:
You'd have to open up the gear-case and see how the shaft is attached to the gear inside.
If its just a setscrew, you've got a very easy fix. Just make sure to lock-tite it when you replace it on the new shaft.
If its pressed in, not so easy, but do-able at a machine shop for a few bucks (or perhaps a HS or college class-shop for nada)
If its pinned... well, you have to put a pin-drive on the new shaft too, meaning drilling the steel rod.
Got any way to show the scale of those beasts?
WhiteWolf
