The wheel you must get for the Jato are
ANY 2.2 Wheel that will fit the Nitro Rustler. the front and rear wheels are differnt. So make sure you get Rears for the rear and Fronts for the front. Differace is Rear is Hex drive, front has holes for 5x11x4 bearings. I would get Proline Edges for the front in the sand Also Panther makes a set front and rear's for 1/10 scale 2wd [link=http://www.pantherteam.com/index.php?main_page=product_info&products_id=233]Paddle tire set[/link] that look cool. I am not running any foam in my sand paws, I just taped them. They are a very stiff tire compare to the others i am running. Also you will have to either get this [link=http://www.neweramodels.com/item.cgi?part_id=2748]2.2 conversion[/link]or as I did just get 4 #10 washers from the local hardware store and put them on befor you mount the front wheels. So it will take up the slack since they are narrower hubs. The rears will rub for a sec. if you don't get the conversion kit but has not hurt anything on my Jato. I would get at least 3 glow plugs. i use McCoy 59's Also would get a Temp gun. It is the only way to tune you new ride correctly. You did not say anything about battery for the EZ start and a charger for that.
Don't feel like you are asking to many question. That is how we all learn.
Here are some link's from tower that will help you!!
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDND9&P=0]6 Cell Nicad EZ start[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHFP5&P=0]RX Battery Pack[/link]
Something like this to charge both batteries[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKLP3&P=7]like this one[/link]This is the charger I use.[link=http://www.dynamiterc.com/Products/Default.aspx?ProdID=DYN4049]Dynamite charger[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXZS53&P=ML]Front wheels[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXZS52&P=7]Rear wheels[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJGR6&P=7]Glue for New Tires[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXRA06&P=ML]Glow plug[/link][link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEMG5&P=0]Temp Gun[/link] I cann't think of any thing else. If you have more Question just PM me.
CTDb
ORIGINAL: XxHarobiker
My parents want to order my stuff for christmas.
Hears my list so far:
-Traxxas Jato RTR Combo
-Traxxas Top Fuel 20% Quart (4)
-Pro-Line Sand Paw 2.2 Truck Rear (2)
-Pro-Line Impact Firm Foam Insert Truck (2)
-Pro-Line Dirt Hawg 2.2 Front/Rear Truck (2)
what rims will fit this??
please answer asap.
