RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 12-07-2005 | 06:42 AM
  #148
catfight
Default RE: Bdavison's E-flite Blade Assembly
ORIGINAL: SonicFury
ORIGINAL: L0stS0ul
Check this page out for detailed info on the sticky collective issue on the blade. Be aware that horizon has released an upgrade to the blade around the middle of september that introduced a 3 ball bearing blade grip that helped to remove the issue. If your manual has an insert in it that includes info on this upgrade then you don't have "the" sticky collective. It could be something else.
[link=http://www.rcgroups.com/forums/showthread.php?t=382982&highlight=sticky+collectiv e]Horizon Hobby Blade CP Sticking Collective Problem Resolved For Free!! [/link]
Oh wow, thanks a bunch for that. I couldn't find any insert on an upgraded blade grip in my manual. Is there any way to tell by looking at my heli w/o taking it apart to see if I have the upgraded blade grip or not? I mean I bought my Blade new mid-November so it should be upgraded if they did it in September, right?
If your servos and 4 in 1 are made of a semi- transparent plastic, then you have a new version with the 3 BB, otherwise not. Good luck :0)
