RE: E-FLIGHT BLADE CP
[quote]ORIGINAL: stimpsonjcatt
Horizon CNC Swashplate Problems
Hey Gang,
Just installed the swashplate last night with no luck.
Scott,
I had or have the exact same problems. I to installed the Century swash then thought the Eflite would be better so I bought them.
I had to adjust the servo links but that isn't a big problem. I think the ball links fit is to tight so I worked them and added some oil. I have two Blades one conversion came off with out a problem but the other has a problem. At this time I am suspicious my throttle servo has a glitch. So I will switch it to see if the problem follows the servo. I also found the swash response is much slower then the original swash. I also had to adjust the blade pitch to get more pitch.
Keep each other informed as to our progress.
