RCU Forums - View Single Post - CA Hinges on UCD
Old 11-16-2002 | 02:28 AM
supertiger
Default metal gear servos problems
I know this has nothing to due with CA hinges, but I'm in the middle of assembling my u-can-do and i was going to install 5 Cirrus metal gear servos they had around 100 ounces of torque each, I've always used these servos for my rudders in all my planes with no problems and this is the first time i put more than one mettle gear servo on the same plane. The problem is that if i move either the ailerons or elevator i get a single glitch on all the other flight controls not a continuous glitch just a hit and it doesn't happen every time you move a flight control but just enough to cause concern, Ive removed all but one of the mettle gear servos "rudder" now and replaced them with 60 once plastic BB servos and everything works great now . is there any reason I'm not able to use more than one mettle gear servo at a time.
