RE: TNX PRO discontinued ?
Because mayhem is an expert in all things RC.(still giving advice on products you've never used)
Also yes the TNX pro will be replaced, the TNX concept should have been your first clue, as someone said before the new TRF suspension arms are comming out along with some cvds, blue anodized chassis and some other things I belive. Should be an even more potent combination with more tuning options and the drive line wear problem solved(only some have reported this)
