worped wing
hi all
I AM BUILDING A 4*60 (MY FIRST KIT) AND I HAVE RUN INTO TROUBLE. WHEN I FINSHED ONE OF MY WINGS I SAW THAT THE WING IS BOWED. I THINK IT IS FROM USING A BUILDING BORD THAT IS NOT HARD ENOUGH. THE TABLE HAS A FOAM TOP AND I WAS USING FOAM BOARD TO STICK PINS TO. ONE WING DID FINE BUT THE OTHER IS BOWED HOW DO I GET THE BOW OUT. CAN I WET IT WITH WATER AND USE HEAT? HELP!! HELP!!HELP!!
