RCU Forums - View Single Post - 3d electric flying
Old 12-09-2005 | 04:54 PM
bdavison
Default RE: 3d electric flying
I like it. There are a few things on that plane that should make it fly REALLY well.
Swept leading edge with tapered tips, the long tail, the huge elevator....all that equals a plane that should track really well....like pattern airplane kind of tracking.
Judging by its looks, the ailerons are going to be SUPER fast. First flight, use low-rates. 1/2" travel past neutral should be enough to get some good roll rates...run it up to 1" travel....Ill bet it rolls so fast it twists the tail.
Even though the elevator is large, I think its gonna be just about right. If you slow it down in a harrier...I have a feeling you'll be all over it, probably going to get real sensitive at slow high alpha flight.
They have the elevator and rudder servos in the back, which means you are going to need extension cables to reach them, its also going to be fun trying to "fish" those cables to the reciever. BE VERY careful when you mount the servos in the back. Most of these types of planes have really light balsa back there, and if you apply too much pressure its easy to break the balsa where the servo mounts.
The nose is kinda short, I dont know where they tell you to mount the battery, but I have a feeling your going to have to mount it REALLY far forward to get the CG in the right place.
Even though its really big, having transparent covering can cause you some problems in the air if you dont have identifying graphics to tell you which is top and which is bottom. Get it downwind, with the sun shining through the wings while your starting a turn..you'll quickly wish you had put some stripes on it to identify top and bottom.
I just use white stick-on monokote. Cut some squares, and put a checkerboard pattern on the bottom of the wing. The white reflects really well, so you can see it.
Looks like it would be a fun plane to fly.
