Engine won't shut down
wd 40 is a chlorinated solvent...reason it is not allowed for aircraft use.
per FAA..MOT..boeing..
if used in an older eng..with some rust,
it breaks rust loose and???right,it goes through engine.(rust or corrosion is???
metal oxide..good for lapping rings and cylinders) get the MSDS sheets on the products you use and learn.
