RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 12-09-2005 | 06:45 PM
  #3825
Jack211
Default RE: U-Can-Do 3d 46?
[quote]ORIGINAL: Rocketman_
ORIGINAL: Jack211
...see the way the pushrod is bent, two 90 degree turns for the right elevator.
Judging from the way that long arm looks in your photo you could just as well have used a straight push rod and put the control horn on the bottom.
Rock, I thought so, too, but THEN the elevator works OPPOSITE the other side. Try it. On the Can Do .60 there's enough room to put one elevator servo arm UP and the other one DOWN while keeping the horns on the SAME side. The .46 doesn't have that room. I played with that bird for more than an hour reversing the servos end for end, putting the arms up then down.... What you see is what worked, the ONLY way it would work without a reverser.
I am SOOOOO happy to hear that your S3004s are doing the job. I had NO idea what the .06 oz/inch difference would make in the long run. You give me hope. I do NOT want to crash that bird because of a servo failure.
Thanks, Rock.
