RE: P-6E Curtis hawk (build thread)
If you look inside the fuse on either side of the fuel tank you can see the hardwood they are refering to. The red arrows are supposed to point forward -- the Super Stearman had the same stickers. The black tube is supposed to be cut into section to fit the front lip of the cockpit -- the instructions say the tube was already split, but I had to slit mine down the center and then cut into sections that fit.
