I also picked up the CG Yak the moment it came in the door at the LHS. (I work there
Here's a shot I took after mocking it up...
I've since installed the landing gear and control surfaces.
The only problem I've ran into so far is that the slots in the fuse don't allow the landing gear bolt holes to line up. I needed to remove about 1/8" of material on the rear of the slots in both the fuse and the interior ply to get all three bolts in each leg to seat correctly.
I weighed the assembled airframe at 8lbs, 9oz.
