Originally posted by GoNavy
Last year I bought two and neither could be used on a Laser 120 and Saito 100. Cline sent a third unit which he assured me was fine. It suffered the same problem: Air bubbles entered the fuel on the outlet of the Cline. The Laser 120 would run, but unevenly. The Saito could not run over 1/2 throttle.
How does air bubbles get into the outlet ? Something inside the regulator is not sealing well ? Did you verify if any air bubbles are getting into the Cline unit to begin with ?..........
